I wonder if someone who knows a bit about common mode chokes and their effects on DC circuits could please help me out. I know nothing about them myself, being just a basic hobbyist.
Consider the following schematic which I've drafted up in Multisim. I have used a transformer to denote a common mode choke. The source voltage I am told is from a switching power supply so should be quite stable. The device attached is a 2.5" hard disk drive, typical power draw 2-3W, which like any hard drive will be switching itself between power states frequently.
I am seeing a breakdown in the insulation of the SATA connector. On one example of the SATA connector I measured a short of 100 Ohm, despite there being no physical metallic short, so this was across the plastic. The other unused circuits measure 2-3 Megohms, which is much lower than you'd expect anyway on these connectors.
So to the question..
When the device is being switched on and off could a high voltage spike be produced by the choke as the magnetic field decays that could be tracking away at the insulation in the connector leading to a failure?
Many thanks for your help.
