I think you are asking for the gate to go into breakdown so a common JFET is not an option to make this work. It is an exploit of a very specific device.
While it can be done if properly biased it only serves as a detector for a specific wavelength.
A small solar cell would probably work in this case, but there are a lot of really nice light detector ICs to be found that would replace the entire circuit.
Yea, they probably meant that to be a photodetector wired to create voltage when light hit it.
Photodetectors can be used in two ways. They will create a voltage of their own when light hits them but were originally designed to operate under reverse bias and vary the voltage in the resulting divider circuit.
Not many know that an LED can actually be used as a wavelength-specific photodetector, not very sensitive but very handy when you've got something that has to operate under wildly varying ambient light conditions.
The LED can be replaced by a photo-diode which will work better.
The LED is upside down or the inputs of the opamp are backwards.
The LED or a photo-diode produces a positive voltage (like a tiny solar cell) which is inverted by the opamp so its output stays at ground. Measure the output of an LED or photo-diode (I did) to see the polarity.
You don't need a Jfet, simply use the very high input resistance of the non-inverting input of the opamp instead. The opamp has a positive input bias current which needs a resistor (1M) to ground. Then when there is light on the LED or photo-diode, it produces a tiny positive voltage that is amplified by the opamp to produce a higher positive output.
Thanks Audio, and everyone.
This is where I found it. Last on on the page. http://www.qsl.net/yo5ofh/hobby circuits/led_circuits.htm
I think it's interesting because of the when in light, the output is low and when dark, the output is high. Like an evening switch.
I saw Bill Bowden's circuit on his site and on many other sites.
I was wrong. The circuit does have an output high when there is no light. My modification without the Fet has an output that is high when there is light.
My issue is I have a pile of recycled parts but I don't know of any common jfet's. Like the npn c1815, I was hoping someone would know of a couple so as to give me something to look for.
They are only one of the suppliers that can be used as information resources, but they are probably the best. If anyone knows of other suppliers as good or better I would like to know about them.
It is just the best way to answer customers questions, and it also means that if the customer insists on asking questions over the phone you have the information there for your order operators to check. Most customers would rather look for the info on their own as long as it is so easy. Happier better informed customers are good for business.
There were a very few of what you might call "common" JFETs but during their short-lived life as a discrete component - everyone had their own number for the newfangled devices. It wasn't until MOSFETs came along shortly thereafter that we got a somewhat logical numbering system from some manufacturers for the power ones and a group of "favorites" for the small signal varieties.
MOSFETs were far more forgiving and obviously more efficient so they quickly replaced JFETs.
http://www.mouser.com is my supplier of choice because they'll treat the smallest customer as if he were a huge corporate buyer. On the other hand I've found Digi-Key to be less cooperative and often more expensive.
As mentioned above Mouser's website is easy to navigate. I limit my requirements down but not to the very last, sometimes a part didn't get classified as "bulk" or they didn't have an input for that spec which means if you've selected it in the filters you can miss something. Once I've got it narrowed down I also use the pricing sort arrow then go down the list of the less expensive ones that they show as in stock.
