Common - Emitter
Discussion in 'Homework Help' started by oracle_dfx, Feb 23, 2005.
  1. oracle_dfx
    Sep 19, 2004
    Hi, Would anyone know why the output signal of the common emitter amplifier is out of phase by 180º? If available, pls include the computations that mathematically prove the inversing of the signal.. Thanks!
  2. mozikluv
    Jan 22, 2004
    1,437
    check the books authoured by Hayes & Horowitz, Keith Brindle, Don Canon to say a few. :)
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    Hi oracle_dfx,
    If you haven't read it already, there is a pretty good introduction to common emitter transistor operation in the Volume III Semiconductors on this website. Well worth reading.
    Good Luck
  4. dragan733
    Dec 12, 2004
    152
    Let's see how were the calculations, here
  5. oracle_dfx
    Sep 19, 2004
    dragan thanks for the calculations,, helped a lot..^^
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is a 5 page analysis of the CE transistor amplifier that establishes the fact that this configuration does produce an output voltage signal that is an inverted version of the input voltage signal.
    I have zipped up the 5 files that were previously posted individually to both reduce the size of the posted file as well as make it less cumbersome to download.
    [attachmentid=466]
  7. duqamoq
    Mar 23, 2005
    It's all very well to go through the rigorous analysis, but it's also important to have a good conceptual understanding of this phase inversion. The CE transistor gets its collector bias from Vcc through a load resistor. The collector side of the resistor is the output. When the transistor is turned on harder (through an increase in base potential) more current flows into the collector through the load resistor, increasing the voltage drop across the resistor. Since the top of the resistor is at a fixed voltage (Vcc), the collector side has nowhere to go but down. Hence a rise in base potential causes a fall in collector potential (all with respect to ground, of course).
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Good point, duqamoq.
    An explanation of the basic factors that account for the inversion in the CE stage makes the mathematical expressions easier to understand and appreciate.
  9. Xeeshan Qureshi
    Member
    Jan 13, 2009
    14
    thanx a lot for the answer, this precisely was my question.
