Common emitter BJT transistor circuit
Discussion in 'General Electronics Chat' started by mghg13, Oct 5, 2014.
  1. mghg13
    Jul 17, 2013
    63
    Hello guys,
    In a simple CE npn BJT circuit, is it possible to have some leakage current flowing from ground through the emitter terminal to the base IF a negative voltage is applied as input to the base?
    thanks
  2. ramancini8
    Member
    Jul 18, 2012
    447
    119
    Yes, the B-E junction acts like a diode, so there is reverse leakage current. In fast switching circuits high negative voltage was applied through current limiting resistors to the base to suck charge out of the junction fast. If the applied negative voltage exceeded the B-E breakdown spec the junction would zener. Later it was proved that repeated reverse breakdown caused a beta degradation.
    mghg13 likes this.
  3. bertus
    Administrator
    Apr 5, 2008
    15,798
    2,384
    As said the reverse voltage breakdown is given in the datasheet as Veb0.
    See the picture for an example:
    Bertus
    mghg13 likes this.
  4. mghg13
    Jul 17, 2013
    63
    Thanks ramancini8 and bertus. Exactly what I wanted to know.
