Common Emitter Amplifiers
Discussion in 'Homework Help' started by electricShOcK, May 6, 2009.
  1. electricShOcK
    Apr 15, 2009
    For the common emitter amplifiers why is the voltage at emitter always less than the voltage at base??:confused:
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  3. PRS
    Aug 24, 2008
    989
    35
    The emitter-base junction is basically a diode. Current passes through a diode in only one direction. The voltage drop is due to the diode's resistance and is about .6v for silicon and .2 volts for germanium. The resistance is given by the thermal voltage divided by the current. At room temp this is about 26mV and at a current of 1mA we get a diode resistance of about 26 ohm.
  4. Ron H
    Apr 14, 2005
    7,050
    657
    The resistance you are describing is the small-signal or dynamic resistance. It does not explain the ≈0.6V Vbe. The forward drop can be calculated from the diode equation as a function of current, if you know the saturation current and the emission coefficient.
  5. PRS
    Aug 24, 2008
    989
    35
    Thanks Ron. I stand corrected. But Electricshock, the diode resistance with the base current passing through it is what reduces the voltage.
  6. electricShOcK
    Apr 15, 2009
    Thank you got it :D
