Common Emitter Amplifier
Discussion in 'Homework Help' started by Madgesture, May 2, 2010.
  1. Madgesture
    May 2, 2010
    5
    A technician installs a transistor, in a common emitter layou, with the Collector and Emitter terminal reversed. What would be seen a cross the load resistor?
    Any help would be greatly appreciated. On the last page of the homework and my brain is already fried.
    Mike
  2. hobbyist
    Distinguished Member
    Aug 10, 2008
    773
    62
    NPN transistor to conduct:
    Collector more positive than base reversed biased
    base more positive than emitter forward biased
    PNP transistor to conduct:
    collector more negative than base reversed biased
    base more negative than emitter forward biased.
    Madgesture likes this.
  3. studiot
    Nov 9, 2007
    5,005
    515
    Well this is still homework, with or without fries, so we shouldn't tell you directly without you say what you think first.
    So here are some hints.
    Firstly the question asks what is the voltage across the load resistor, not across the transistor.
    So where is the load resistor in a CE amp?
    OK so now is the transistor on or off?
    So is it passing current?
    So what does that tell you about the current in the load resistor?
    So what does that tell you about the voltage across the load resistor?
    Does it make any differernce to the answer if the transistor is NPN or PNP?
  4. Madgesture
    May 2, 2010
    5
    What I see with the transistor installed backwards is an NPN, Common Collector Amplifier. The Load resistor will now be on the emitter. The Output on Load Resistor will basically be the input voltage, as there is very little or no voltage gain in in a common collector amplifier, just power and current gain.
  5. Madgesture
    May 2, 2010
    5
    The load resistor on an NPN CE Amp is on the collector. The transistor installed backwards it will be on the Emitter making the cicuit a NPN CC Amp
    There is 1.08V at the base so the Base Emitter junction will be forward biased.
    With the BE forward biased there will be current passing and also current and voltage on the load resistor.
    Since the this is now a CC Amp the Output Voltage will be the roughly the same as the input as there is no voltage gain and the Output will be in phase with the input.
  6. studiot
    Nov 9, 2007
    5,005
    515
    Just try answering my questions is sequence.
  7. Madgesture
    May 2, 2010
    5
    On the Collector
    On 1.08V at Base before reversal
    Yes
    It will be higher than input current
    There will be some voltage
    Does it make any differernce to the answer if the transistor is NPN or PNP? Yes
  8. studiot
    Nov 9, 2007
    5,005
    515
    Look at my sketch, (you could have done one of these).
  9. Madgesture
    May 2, 2010
    5
    So, basically with reversing the Transistor it is going from a CE Amp to an CC Amp.
    The major differences would be:
    No Voltage Gain in CC Amp
    No Phase Shift in CC Amp
  10. hobbyist
    Aug 10, 2008
    773
    62
    Here is a hint:
    draw 2 circuits using a CE layout properly biased for a NPN and a PNP.
    Then redraw them with the transistors backwards with there respective circuits.
    Then using the info in above posts analyse what you see.
    The key is don't change battery polarities when you change the transistors to be backwards.
    To change from CE to CC with backwards transistors the polarities of the battery needs to be reversed as well.
  11. Audioguru
    Dec 20, 2007
    9,411
    896
    When the emitter-base junction of a silicon transistor is reverse-biased then it has avalanche breakdown (like a zener diode) at about 7V.
  12. Ron H
    Apr 14, 2005
    7,050
    657
    An inverted transistor (collector and emitter swapped) still acts like a transistor, except the beta is low, and generally unspecified. Also, as AG stated, Vbe is now Vce, so the breakdown voltage will be low.
    There is insufficient information in the statement of the problem to give a quantitative answer.
    The circuit is NOT now a CC amp. It is still CE, but with the characteristics mentioned above.
    EDIT: From Wikipedia:
