common emitter amplifier
Discussion in 'Homework Help' started by smokeygolf, Oct 23, 2006.
  1. smokeygolf
    Oct 23, 2006
    12
    hi, i need to design a common emitter amplifier with:
    d.c supply 15V
    gain 200
    low frequency cut-off 50Hz
    signal source impedance 600 ohms
    transistor to be used 2N2222
    i have done the gain part but am lost in the rest of the workings:confused:
    any help would be appreciated:)
    Below is my circuit diagram
    http://upload.wikimedia.org/wikipedia/commons/b/be/Common_emitter.png
    I have set RC to be a 2K and Re to be 10ohm to give me a gain of 200.
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    We need to see your circuit and results before we can give help.
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    You may find the suggestions contained in the How to post guide that will give you some ideas on the type of information that would be beneficial to provide as part of your post.
    hgmjr
  4. smokeygolf
    Oct 23, 2006
    12
    anyone know
  5. Dave
    Retired Moderator
    Nov 17, 2003
    6,960
    145
    You need to follow the advice of both beenthere and hgmjr. Without the circuit daigram and the workings you have done so far there is little anyone can help you with.
    Dave
  6. smokeygolf
    Oct 23, 2006
    12
    the setup of my circuit is above
  7. JoeJester
    Apr 26, 2005
    3,403
    1,227
    Smokey ...
    You might want to tell us the values you selected for each component on the diagram.
  8. smokeygolf
    Oct 23, 2006
    12
    i am just not sure how to go about finding the values:confused:
