Common-emitter amplifier question
beijim
Joined May 11, 2012
First, sorry for my poor English.
The question is shown below.
Here are my calculations, is that right?
Ci) Rc:
Because Vce=Vcc/2 , so Vcc=Vce*2
Vcc=12V
Rc=(Vcc-Vce)/Ic
=(12-6)/15*10^-3
=400Ω
IB:
I know IB=Ic/βDC but i don't know how to find βDC :eek: !
Because I know RB, so I find another way :
RB=(Vcc-VBE)/IB
This time, I find that I don't know how to find VBE :confused: ...
Because I cannot find IB ...I also cannot find IE and
βDC .
Can anyone help me?
Finally, thanks for you help. :)
Jony130
Joined Feb 17, 2009
5,488
First of all your Vce must be equal to 6V and Vcc = 10V
As for the Vbe simply assume Vbe = 0.6V
And are you sure that R1 is 10K ohm ? If this is the case I'm very strange surprised.
Since most of a BJT as a current gain greater than 100.
And for condition as in you diagram the BJT will by in saturation.
30,824
You are told VCC = 10V.
Why do you think VCE= VCC/2 ?
This is a wrong assumption.
You are also told that R1 = 910KΩ
You do not need to make any assumptions about VBE. If this is small it will not affect the calculation for IB.
Assuming VBE= 0.6V will give a better estimate of IB.
beijim
Joined May 11, 2012
Thanks for your reply. :D
I would like to know why Vce is 6V? (Sorry for my silly question, because I am a novice in Electricity. :p)
And here are my corrections, is that right?
Ci) Rc:
Given : Vcc=10V, Vce=6V, Ic=15mA
Rc=(Vcc-Vce)/Ic
=(10-6)/15*10^-3
=266.67Ω
Ib:
Rc=(Vcc-Vbe)/Ib
910k=(10-0.6)/Ib
Ib=10.33μA
Cii) Ie:
Ie=Ic+Ib
=15m+10.33μ
=15.01mA
βdc:
βdc=Ic+Ib
=15m/10.33μ
=1452.08
Audioguru
Joined Dec 20, 2007
11,248
A transistor is NEVER biased like that because Beta is a range of numbers. Its beta might be high or it might be low and it changes when the temperature changes.
Usually the base of a common-emitter amplifier transistor is biased from a voltage divider and the transistor has an emitter resistor.
mlog
Joined Feb 11, 2012
276
Chips and Martin pretty much answered the question. The assumption is that the silicon transistor begins to turn on when \(V_{be}\)=0.6 and is fully saturated when \(V_{be}\)=0.8. So the active region is a voltage between those two points.
Audioguru
Joined Dec 20, 2007
11,248
No.
That is an assumption that might be true for only a few transistors.
Vbe changes with the input current and with temperature.
The maximum Vbe of a 2N3055 power transistor with a 4A collector current is 1.5V, not 0.8V and is more when it is cold.
A transistor input is a current, not a voltage. Its input voltage requirement increases a little when its input current increases.
mlog
Joined Feb 11, 2012
276
No.
Of course it is a rule of thumb and is typical of a small signal transistor. There are always exceptions to the "rule," which doesn't make what I said wrong. Thank you for your clarification.
Rick Martin
Joined Jun 14, 2009
31
For what Beijim is doing Vbe=0.6-0.8V is the value, there are ALWAYS variations however when learning and doing entry level small signal circuits Vbe=0.6-0.8V is accepted.
