Common Collector
Discussion in 'The Projects Forum' started by chaosweapon, Apr 5, 2009.
  1. chaosweapon
    Nov 14, 2008
    15
    I am trying to design a Common Collector but I have 2 problems:
    1. The negative part of the ac signal is clipped unless I use a very high dc voltage (such as 100V).
    2. The circuit only works fine at high capacitances.
    Here's a copy of the circuit
    http://forum.allaboutcircuits.com/attachment.php?attachmentid=8527&stc=1&d=1238940076
    By the way, are there any rules of thumb for this type of circuit? I used the R2= (beta * RE) / 10 but I'm not sure whether it is valid since there is no RC.
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    A Common Collector amplifier only provides current gain, are you measuring voltage?
    The base is biased at 10.2V, the signal source looks to be 2.5V.
    Is the capacitor inline with the signal source 1 Farad?
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    It looks like the load resistor is only 10 ohms. Then the output voltage will be very low.
    The 1uF output capacitor value is much too low for 50Hz feeding 10 ohms.
    The max allowed current in a BC547 transistor is only 100mA.
    To drive 10 ohms you need a PNP transistor and an NPN transistor in series.
    My circuit will work but its input impedance is fairly low.
  4. chaosweapon
    Nov 14, 2008
    15
    I am actually working on a class A amplifier. The purpose of the Common Collector is as a buffer between the Common Emitter and the load (10ohm resistor). The capacitors are 1Farad each, else the circuit doesn't work correctly. Maybe I'll use a Darlington Pair to raise the input resistance. Common Collectors are good for driving low loads. I still can't figure out why the negative part of the input signal is clipped.
  5. KL7AJ
    Nov 4, 2008
    2,047
    295
    Hi Chaos:
    Almost certainly you have to adjust your bias....emitter followers are particularly picky about this, because the current gain is so high. With no input signal, measure the voltage right at the emitter...it should be exactly half your supply voltage. If not, adjust your biasing resistors until it is.
    Eric
  6. thatoneguy
    Feb 19, 2009
    6,357
    718
    The circuit has too much gain. Increased the base drive by changing the bias resistors lower by a factor of 10 stopped the clipping (5.6k/4.8k). The 10Ω load pulls the emitter low pretty quickly.
    --ETA: Teach beat me to it.
  7. chaosweapon
    Nov 14, 2008
    15
    The low load is causing the clipping problem but I have no idea how to solve it.
  8. hgmjr
    Jan 28, 2005
    9,030
    214
