I'm studying the common collector configuration explained on the site. I'm confused about the current gain of the circuit.
Let's take the image from the article:
I don't understand why there is any current gain at all. I mean, when you connect a load to Vout (node 0 and 3), the Rload is effectively decreased. Doesn't this proportionally increase base current?
If Vin=5V and the new load impedance (Rload2) is 10R, base current would be 0.5A. And because the voltage over the output load, in this case Rload2, is always 4.3V, how can the current through Rload2 be anything else than 0.5A, equaling base current?
