I just want to understand the reason for calling this amplifier common-collector. the reason for my confusion is that the collector lead is not common between the input circuit and the output circuit. and I cannot understand the following from the text
It is called the common-collector configuration because (ignoring the power supply battery) both the signal source and the load share the collector lead as a common connection point as in Figure below.
Still the input between the base and emitter and the output in the emitter.
