Common Base output characterstics
Discussion in 'The Projects Forum' started by rudra, Dec 29, 2010.
  1. rudra
    Dec 29, 2010
    Hi All,
    i m confuse in common base output characteristics of NPN Transistor that why the Collector current drops and goes to zero ,when there is increase in negative values of Vcb.....I know it goes in Saturation Region....but what exactly happens when we increase in fwd bias of collector base junction in this case.....i mean when we increase forward bias the current should increase but it decreases......
    Please help me out.............:confused: :confused: :confused:
  2. hgmjr
    Jan 28, 2005
    9,030
    214
    Read up on the CB amp here in the AAC ebook.
    hgmjr
  3. rudra
    Dec 29, 2010
    To hgmjr,
    Sir it does not explain the output characteristics.....
    Pls help......
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    The collector voltage of an NPN common base transistor stage is controlled by holding the base at a constant voltage and then driving the base so that the base-emitter junction is either reverse biased (NPN in cutoff) or forward biased (NPN in saturation).
    hgmjr
  5. rudra
    Dec 29, 2010
    Pls explain me in detail............
    and what is the way to download attachments in all about circuit forums...
    I m a newbie here.....I want to download attachment Id 466
  6. hgmjr
    Jan 28, 2005
    9,030
    214
  7. Ron H
    Apr 14, 2005
    7,050
    657
    I think you meant emitter.:)
  8. CDRIVE
    Jul 1, 2008
    2,223
    99
    I beg to differ. I just read through the CB Tutorial and it's exceedingly thorough, concise and accurate. It's also well documented with schematics and graphs. Off hand, I can't think of a single thing to add to it. ;)
