Common base emitter signal attenuation inpuy
Discussion in 'General Electronics Chat' started by kuannygohcheetatt, Sep 20, 2014.
  1. kuannygohcheetatt
    Oct 31, 2013
    61
    When i supply my signal at the input of the common base transistor,i directly measure the input using oscilloscope. To my dismal, the signal attenuates, is it becasue of the low input impedanc eof the transistor? Loading effect?
  2. MrChips
    Oct 2, 2009
    12,648
    3,458
    What do you mean by common base emitter?
  3. kuannygohcheetatt
    Oct 31, 2013
    61
    I am aorry my mistake it os common base transistor
  4. MrChips
    Oct 2, 2009
    12,648
    3,458
    It would help us to help you if you provided a circuit schematic.
  5. kuannygohcheetatt
    Oct 31, 2013
    61
  6. kuannygohcheetatt
    Oct 31, 2013
    61
    I straight
    measure the input at i but the 25 mv attenuate before it even enters the transistor, my teacher say it happens because of a reason but i duno what is that reason
  7. MrChips
    Oct 2, 2009
    12,648
    3,458
    Did you try to run a simulation?
