Common base emitter junction with resistor at the emitter
Discussion in 'Homework Help' started by hitmen, Dec 5, 2008.
  1. hitmen
    Thread Starter Active Member
    Sep 21, 2008
    159
    This exam question has stumped me too. A resistor is placed at the emitter of the common base-emitter junction instead of the collector. I was stumped.
    For NPN transistor assume: Vbe = 0.6V when just on
    Vbe = 0.7V Bf = 100 in active region
    Vbe=0.75, Vce = 0.2V
    Question : When Vin = 5V in fig Q4a, transistor is in active region
    (i) Write equation to show relationship between Ib, Ic , Ie
    (ii) Express Ic and Ie in terms of Ib
    (iii) Hence determine Vo.
    Here is my answer:
    Ib + Ic = Ie
    Ic=100Ib
    Vo = 10-0.2 = 9.8V (obviously wrong)
    Can someone guide me through?
    Thanks.
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Your attachment is blurry, and the lower part of the schematic is clipped off.
  3. hitmen
    Sep 21, 2008
    159
    I have already posted an better auto adjusted image. I have already typed in the question and my answer
  4. Ron H
    Apr 14, 2005
    7,050
    657
    Auto adjusted, huh? I guess I need new glasses.:rolleyes:
    What is the value of the base resistor?
    You said Vin=5V. Your attachment appears to show Vb=0.5V.:confused:
  5. hitmen
    Sep 21, 2008
    159
    Ignore the statements in the attachment just looking at the diagrams will do:) I know my photography skill sucks. For Vb = 0.5V, I knew how to do that part of the question.
    It is the next part that is the problem. In the attachment, Vcc = 10V, Vb = 5V, Rb = 10kΩ, Re = 5kΩ. Find V o (located just above Re).
    Thanks.
  6. Ron H
    Apr 14, 2005
    7,050
    657
    It's simple algebra.
    Vbase=5-IbRb
    Vo=Vbase-0.7
    Ib=Ie/(β+1)
    Ie=Vo/Re
    Solve for Vo.:)
  7. hitmen
    Sep 21, 2008
    159
    There are too many unknowns. Do we need Vcc to come into the picture? How are we gonna calculate Ic?
  8. hitmen
    Sep 21, 2008
    159
    I got it. I got it. 4 equation and 4 unknowns. Thanks!:)
  9. Ron H
    Apr 14, 2005
    7,050
    657
    Rb is known.
    Re is known.
    β is known.
    There are not too many unknowns. I calculated the answer. You can too.
    Vcc is irrelevant as long as it is higher than +5V, and it is. I think you already know that Ic=β*Ib.
    I'll give you some more hints.
    You can start with Vo=Vbase-0.7, and substitute the above equation for Vbase. For Vbase, substitute its equation. For Ib, substitute its equation. For Ie, substitute its equation. If you do all that, you can calculate Vo.
    EDIT: I was composing while you posted your most recent entry.
