In the circuit seen in the attachment , can you please help me write the KVL equation around the base-emitter loop (assuming the transistor is in forward-active mode)?
Show us your attempt and if there is any problems someone will correct you.In the circuit seen in the attachment , can you please help me write the KVL equation around the base-emitter loop (assuming the transistor is in forward-active mode)?
Your KVL is correct, and identical to the one given by your book.ok the book says that its;
V+ = I<EQ>*RE + VEB(on) + (IEQ/(1+β))*RB
now i dont get where (IEQ/(1+β)) came from
my own attempt was V+ = I<EQ>*RE + VEB(on) + I<BQ>*RB
by Aaron Carman
by Jake Hertz
by Jake Hertz
by Jake Hertz
