Common Anode 7 segment display resistor
Discussion in 'The Projects Forum' started by rmazumder, Aug 2, 2014.
  1. rmazumder
    Aug 2, 2014
    I have a common anode 7 segment display and in all the circuit example i see connection from vcc to common anode pins and from segment pins to current limiting resistor to ground.
    This way I need 7 resistor. Will it not work if I connect the current limiting resistor from VCC to the common anode and segment pin directly to the ground, as this way I will need only two resistor.
    Excuse me if it is a lame question as I am new to elecronics I am getting confused here.
    Thanks in Advance,
    Ruhul
  2. djsfantasi
    Apr 11, 2010
    2,906
    879
    It will work, but not well. A "1" will appear much brighter than an "8".
    Seven segments require more current than two. A single current limiting resistor will not adjust to the varying load.
    rmazumder likes this.
  3. Dodgydave
    Jun 22, 2012
    5,155
    772
    No, you need all the resistors, as one resistor alone makes the leds all in parallel,so they don't work.
