commom emitter amplifier
Discussion in 'The Projects Forum' started by Traveler, May 31, 2009.
  1. Traveler
    May 31, 2009
    Hi all, can someone assist with a lab assignment.
    I am trying to design and build a common emitter amplifier with a gain of 12 that works for frequencies above 1000Hz. The input resistance is at least 500 ohms and the load is 1000 ohms. I do not want to use an emitter bypass capacitor, what else capacitor value can I use. How should I design this circuit?
    Any assistance is greatly appreciated.
  2. CDRIVE
    Jul 1, 2008
    2,223
    99
    This is a class assignment so we can't design it for you. What we will do is help you through it if you post your schematic. Here's a tip: Set the gain of the amplifier with the un-bypassed emitter resistor.
