Comments/corrections on H-bridge
Discussion in 'The Projects Forum' started by tracecom, Aug 25, 2014.
  1. tracecom
    Thread Starter AAC Fanatic!
    Apr 16, 2010
    3,879
    1,396
    I am trying to build a controller for a DC gearhead motor: 3V to 18V compatible, draws less than .5A with no load. I don't need speed control, but I do need to reverse direction. I plan to use a 5V μC for the logic, and 12V for motor power. Please comment/correct my schematic. Thanks.
  2. ronv
    Nov 12, 2008
    3,404
    1,478
    I would add some clamp diodes.
    I'd kind of worry about shoot thru - where the top transistors turn on before the bottom one is fully off. Both would be a lot worse if you were pwming it.
    tracecom likes this.
  3. Sensacell
    Jun 19, 2012
    1,184
    277
    I agree- there will be heavy shoot-thru currents during the switching interval.
    Clamping diodes are inherent in the FET's - the body diode.
  4. crutschow
    Mar 14, 2008
    13,508
    3,385
    If you turn off the power before you reverse direction, there shouldn't be any problems. If you try to reverse with power applied, then there will be stress on the motor and FETs.
  5. tracecom
    Apr 16, 2010
    3,879
    1,396
    Thanks for the input.
    I should have said in my original post that the application is (yet another) automatic door opener/closer for a chicken coop. The power will always be off before the motor is reversed.
    So, am I correct in my understanding that the design is satisfactory for my application?
  6. ScottWang
    Aug 23, 2012
    4,933
    777
    The input current Ii = (5v-0.7V)/1K=4.3mA, then the Ic will be 43mA, it's too much, the R1 can change to 3.9K and adding a Rbe as 2.2K to avoid when the input is floating.
  7. tracecom
    Apr 16, 2010
    3,879
    1,396
    Do you mean that I should change R3 and R4 to 3.9k, and add a 2.2k from the base of Q5 and Q6 to ground? Thanks.
  8. ScottWang
    Aug 23, 2012
    4,933
    777
    Yes, If the I/O current of pic is enough then you should do.
  9. shortbus
    Sep 30, 2009
    4,096
    1,692
    Has something changed in the makeup of mosfets? I see more and more people saying that the intrinsic diode present in a mosfet is all that's needed. It hasn't been that long ago(a year or two) that people were saying to ignore the intrinsic diode for protection, that it was of a unknown/inferior value.
    While this is what was said for mosfets, an IGBT is another matter. In an IGBT the diode present is a separate known value. It, the diode in an IGBT, is a real added discrete component in the IGBT, matching the characteristics of the IGBT.
    Help me to understand this new thinking on mosfet please.
  10. MikeML
    Oct 2, 2009
    5,451
    1,066
    Why screw with it? I needed several, so I just bought some of these. They work for regular DC motors, not just steppers.
    I needed PWM for speed control, and reversing of a PM 12V motor which draws a maximum of 2.5A. I used an PWM output pin from an Arduino for the speed control and a separate output pin for direction.
  11. tracecom
    Apr 16, 2010
    3,879
    1,396
    You are correct, of course. That seems to be the case more and more often: cheaper to buy from China than to build. Still, I had all the parts for this, so I built it anyway. I will probably order some of the ones from China for future projects. Thanks.
  12. crutschow
    Mar 14, 2008
    13,508
    3,385
    A resistor from base to ground is not needed for normal operation.
  13. SgtWookie
    Jul 17, 2007
    22,183
    1,728
  14. ronv
    Nov 12, 2008
    3,404
    1,478
    shortbus likes this.
  15. crutschow
    Mar 14, 2008
    13,508
    3,385
    Below is the simulation of a simple bridge circuit with a single control input that should work fine if you don't switch when power is applied. It does require the lower N-MOSFET to be a logic-level type if you want to control it with a 5V logic signal.
  16. SgtWookie
    Jul 17, 2007
    22,183
    1,728
    Crutschow, try replacing the 10 Ohm load resistor with an inductor of about 2H, and a resistance of perhaps 6 Ohms, and increase the battery source resistance to around 20m Ohms. Then take a look at the Vgs of the upper MOSFETs during ON/OFF transitions. Remember, if Vgs excursions exceed ±20v, the MOSFET gets smoked.
  17. Sensacell
    Jun 19, 2012
    1,184
    277
  18. ronv
    Nov 12, 2008
    3,404
    1,478
    Yes schottky or often another FET that turns on shortly after the bottom one turns off then the FET becomes the clamp and the diode can be small because it only carries current for a short time.
  19. crutschow
    Mar 14, 2008
    13,508
    3,385
    The op stated (Post #5) that the power is off when the bridge is switched. (I did show the bridge switching under load but that was just for simulation purposes). But the turning off of the switch to the battery would generate a large transient so the bridge power connection should be bypassed with a reverse-biased diode to ground to absorb the negative transient (which I should have included but did not). Thanks for bringing that to my attention.
    I don't see a problem with turning it ON. And 2A * 20m ohms is only 40mV so I don't see how the battery impedance is a factor. :confused:
  20. shortbus
    Sep 30, 2009
    4,096
    1,692
