Comment "On rectifiers and diodes"
Discussion in 'General Electronics Chat' started by C H Cooke, Sep 15, 2011.
  1. C H Cooke
    Sep 15, 2011
    A diode may be thought of as like a switch: “closed” when forward-biased and “open” when reverse-biased.
    I disagree with with this statement-when forward biased, electrons flow
    through the diode-granted opposite to the conventional current flow
    direction. When reverse biased this current is not allowed
    So why say the switch is closed when forward biased? Your picture shows the light coming on
    when forward biased,and staying off when when reverse biased. So it would again appear that
    forward biased is the "open" switch.
  2. MrChips
    Oct 2, 2009
    12,622
    3,451
    What you say makes no sense. Can you elaborate on why you think that forward bias is the "open" switch?
  3. Adjuster
    Dec 26, 2010
    2,147
    300
    This is simply a problem of definition: a long-established convention that the original poster may not be aware of.
    In normal usage in technical English, an open switch passes no current (think open-circuit). A closed switch can pass current.
    Thinking of an old-fashioned knife switch may help to reinforce the idea. The switch is off when the gap is open, on when the gap is closed.
  4. MrChips
    Oct 2, 2009
    12,622
    3,451
    Ah, I get it! The OP is thinking that "open" means the gate is open and it lets the sheep out:)
  5. colinb
    Jun 15, 2011
    351
    35
    open vs. closed - if you end up combining electrical relay controls with fluid control systems, it gets really ugly. It's frustrating that for electrical circuits, “closed” means current can flow but for fluid valves, “closed” means there is no flow.
  6. shortbus
    Sep 30, 2009
    4,084
    1,664
    Especially when they use water pipes as an analogy of electric flow.:)
