command sending from hyperterminal to thermal printer
Discussion in 'Embedded Systems and Microcontrollers' started by cktcrazy, Sep 12, 2011.
  1. cktcrazy
    Mar 27, 2011
    16
    hello
    i am trying to send command from my computer hyperterminal to fujitsu thermal printer.but i don't know the format by which we can send command from hyperterminal for thermal printer.i am having the RTP5880I thermal printer.
    i have gone through the user manual of RTP5880I. but there the commands are given but the format for sending the command is not given
    for example in case of GSM modem as we use 'AT' command here incase of this printer ,which command is used and if u plz write a total command (for example)
    then its better .
    waiting for your response
    thanks and regards
    cktcrazy
  2. BMorse
    Sep 26, 2009
    2,675
    234
    Have you tried using drivers for the printer? (if any are available.) Does this printer have a Serial, parallel, or USB interface?? Can you post a scan of the command lists from the manual??
  3. stahta01
    Member
    Jun 9, 2011
    133
    21
  4. cktcrazy
    Mar 27, 2011
    16
    i have the user manual attached.i am using serial port.
    commands are there in the user manual but
    i need to know the format by which i can send that command from the hyperterminal of serial port.
    regards
    cktcrazy
  5. BMorse
    Sep 26, 2009
    2,675
    234
    You have to send the control codes and commands to printer in either decimal or hexadecimal..... I do not believe you can send those types of control codes from hyperterminal.....
    Here is the sample code from the user manual for resetting the printer...
    [Name] Printer resetting
    [Function]
    The ESC @ command initializes the printer.
    Code (Text):
    1.  [1B]16 [40]16
    2.
    3.
    4.
    5. here is the equivalent in hexadecimal format used in VB:
    6. (&H1B) + (&H40)
