I've came across one problem which I don't understand. In TCS3772 rgb color sensor is one register called COMMAND, which I don't know how to properly use. It says, you should write bits in it if you read/write from the chip, but I don't know how to access it, cuz there is non address for it.
Any help would be appreciated.
Thanks!
Thanks!
