Combining multiple d.c power sources
Discussion in 'Homework Help' started by smartmachine, Dec 13, 2014.
Thread Status:
Not open for further replies.
  1. smartmachine
    Jun 15, 2013
    Hi!
    For understanding and practically applying, please provide correct answer/info for the above for adding multiple d.c power sources (it would be convenient if the needed answer/info is given as per following question order, with many Thanks.):
    1. Which one of the above is correct, ( (1) or (2) ) ?
    2. In the diagram (1) above, is the wing (b) of diodes really needed in the circuit, if it is correctly
    attached as per schematic?
    3. The d.c power sources are shown here are as rated chargers/adapters. If one of the above (or both) is
    correct, do the batteries (Lead acid, dry cell, and solar panels etc. ...) may also be connected as same as per subject, to prevent circulation of currents and charging each other?
    * Any discrepencies, or detailed guidance in the aboves may be really appreciated for indicating.
    Regards.
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,386
Thread Status:
