OK, I tried another trial run with the kids and realized the 10K pot I was using to set the ref voltage was causing the setup to be crazy sensitive - meaning the laser had to hit the LDR almost perfect to keep the buzzer/counter off. I am still in the "balance all available mirrors on stuff" stage so any movement in the room was causing me major headaches. I "borrowed" a glass light fixture from my bathroom to provide some help so now the laser just has to hit the fixture anywhere and the LDR stays bright enough. I also took some more realistic measurements of the LDR's to help decide the resistor values. The current setup, as shown - with NO siren or buzzer, works really well. I can even open my hand/fingers apart and pass my entire hand through the laser - the counter picks up each finger!
I am an admitted total and complete NOOB, but isn't R10 (10K) a base resistor coming out of the 339? I am confused ...
I am also getting nervous because I realize the flexibility of using the protoboard is almost over - getting closer to trying to really "make" this thing.
I am beginning to think I may have to pass on the siren/buzzer. After I changed out the 10K pot for the 2 resistors, the siren would cause some counts to jump. Not every time, but not good. I am not sure why the 10K pot setup worked with the siren. I also used a 2N3904 transistor at Pin 3 of the 555 for the siren. Please take a look at the circuit below to see if I understood your instructions correctly. It worked, but did have the same count jump problem as when the siren was wired to Pin 3 directly. Also, the Pin3/transistor/siren setup def. sounded whimpy compared to the Pin3/siren. I suppose that is the purpose though - to take the foot off the gas so to speak.No base resistor is needed. LM339 has an open collector output.
