Hello All. I am scratching my head trying to figure out how to accomplish what (at first) seemed like a simple task. In the diagram below, I have two signals (CLKA and CLKB) that vary in frequency (from 5Hz to 20KHz) but always have the same phase with respect to one another. I am trying to accomplish the waveform labeled "IDEAL OUTPUT" the simplist way possible. More info:
- The yellow box shows one complete cycle which repeats over and over. In this cycle, there are 64 positive edges on CLKA and 2 on CLK B.
- I desire an output that has has 16 positive edges (width of pulses not important) with the third pulse removed (IDEAL OUTPUT).
- If removing the thrid pulse is too complicated, removing the pulse directly after the CLKB reference pulse would suffice (ALTERNATE OUTPUT).
- It does not matter if CLKB grabs position 0 or 32 as the postive-going transition upon startup. If this happens, signal CLKB/2 would be inverted, and missing pulses will occur on output pulse 11 insetead of 3(IDEAL)...or output pulse 9 instead of 0 (ALTERNATE). This is ok as long as there is only one missing pulse in the complete output cycle of 16 pulses.
