combinational circuits
Discussion in 'General Electronics Chat' started by vead, Jun 27, 2014.
  1. vead
    Nov 24, 2011
    621
    8
  2. djsfantasi
    Apr 11, 2010
    2,905
    878
    D0 through D3 are individual outputs. The input to the decoder is switched to one of the four outputs, based on the values of the select lines S0 and S1. For example, if S0=1 and S1=1, then D3 is selected ('11b'=3).
    In the case of the linked examples, there is no input but the selected output is set to 1 (and the others are set to 0), based on the select lines as described above.
  3. MrAl
    Distinguished Member
    Jun 17, 2014
    2,556
    515
    You can write the boolean expression for each output.
    For example, D0=A0'*A1'
  4. DerStrom8
    Feb 20, 2011
    2,428
    1,329
    When working with logic gates I find it useful to write the values at the output. For example, if I have inputs A and B going into a NAND gate, then just after the NAND gate I write (A*B)!, and use that for the input to the next gate. Writing the values of the gates starting from the inputs and working towards the output really simplifies the process of determining what you get at the output.
  5. vead
    Nov 24, 2011
    621
    8
    so look third row in table (demultiplexer) A=0
    D0= 00*01=1
    but its wrong
  6. MrAl
    Jun 17, 2014
    2,556
    515
    I am sorry but i dont understand what you are trying to say.
    What i see is under the column for D0 i see a zero when A1=1 and A0=0, which looks correct to me because 1 times 0 (or alternately 1 AND 0) equals 0 (zero) so that looks correct.
    D0=A1'*A0'
    D1=A1'*A0
    D2=A1*A0'
    D3=A1*A0
    These statements show when the associated output (D0 through D3) is HIGH (equivalent to a '1').
    Note the following:
    0*0=0
    0*1=0
    1*0=0
    1*1=1
    Does this make any more sense?
