I was wondering if someone could help me find the values listed to the right here, I'm somewhat familiar with this combination circuit stuff but some of these resistors values are not in here and I know that in a series the current stays the same throughout that series, and parallel the voltage is the same across, so i was wondering if someone could help me find the values below and send me a completed image link I would greatly appreciate it and I would be able to figure out on my own how those worked out to be as such. Here is the link to the circuit drawing.
http://s373.photobucket.com/albums/oo180/dahooligans/?action=view¤t=combinationcircuit.jpg
Here's what I'm having problems with......
I don't understand is that the 2.5Amps between r2 and r3, that will remain the same right? voltage of r2 and r3 would each be 100volts?
parallel to that across R5 is 75volts, so would that make the voltage across R4 having to be 125Volts or just 25 Volts? I would guess 125 volts .
That's one dillema I have....the 2nd dillema is the ams....says 5 ams heading back to the positive so would that make the amperes across R4 and R5 2.5 amps also? and then R1 would be 5 amps, 100 volts?
