Not working in simulation or not irking on a breadboard? If simulator, which one are you using. Not all will start oscillating on their own. You may need to add a seed value of some type or use another simulator.Thank you for the response. I've looked at that page for a few, but haven't had much luck in understanding the comparison of that page to what I've got going here. I've attached the document we are meant to use to draw our circuit. The assignment was to verify with various values of Rg we could get a specific Vout of 5V, 7.5V... etc.
EDIT: I should add that we had to calculate the values of Rg which is why I'm using Vout of 5V with Rg of 403 ohms as my example.
by Jake Hertz
by Aaron Carman
