Colpitts oscillator ampop
Discussion in 'General Electronics Chat' started by beirao, Dec 11, 2012.
  1. beirao
    Feb 22, 2012
    12
    I´m designing the colpitts oscillator in attachment. At first stight, the oscillator is stable, but the frequency oscillates over time; the oscillation is notorious in my aplication. Can you help me?
    Thanks!
    (sorry for my bad english)
  2. beirao
    Feb 22, 2012
    12
    My previous circuit is wrong. The C10 don´t connect the pin 2 of UA741 connect but the R11 and L1; but the circuit continues instable.
  3. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
  4. tshuck
    Oct 18, 2012
    3,531
    675
    Also, your second stage is an open loop amplifier, you will saturate to +5V and -5V very quickly....
  5. beirao
    Feb 22, 2012
    12
    Thanks for your answer. Yes, I use the schematic of this website.
    My inductor is the 5mH. In this case, my goal is vary the frequency by vary the inductor. I replace the capacitor of 10uF by 1uF but is instable too...
  6. beirao
    Feb 22, 2012
    12
    Yes, I want read a frequency in a uC so I transform the output of oscillator in rectangular wave...
  7. tshuck
    Oct 18, 2012
    3,531
    675
    C10 is connecting to the inverting input of stage 1 when it should be connecting to the node R11 and L1 are sharing...
  8. beirao
    Feb 22, 2012
    12
    Yes, I correct my first post in my second post.. ;)
  9. tshuck
    Oct 18, 2012
    3,531
    675
    Ah, yes, you did write that:p.... You should update your schematic when you change it
  10. beirao
    Feb 22, 2012
    12
    I can´t modify the schematic in my first post. So, is there
  11. tshuck
    Oct 18, 2012
    3,531
    675
    It may have to do with your feedback resistor values....
    Try making R11 1kΩ...
  12. beirao
    Feb 22, 2012
    12
    Hum.. I will test. But I think that I tested and the instable is the same...
  13. beirao
    Feb 22, 2012
    12
  14. Ron H
    Apr 14, 2005
    7,050
    657
    Tell us why you want to make a Colpitts oscillator.
    Does it have to use an op amp?
  15. beirao
    Feb 22, 2012
    12
    I need a solution for vary a frequency by inductance variation. I use a colpitts oscillator because thought that was a stable oscillator. Any sugestion? :)
  16. Ron H
    Apr 14, 2005
    7,050
    657
    This Colpitts oscillator works well in simulation.
  17. beirao
    Feb 22, 2012
    12
    Thanks for your answer!
    But your circuit is different of my... what is the better?
    In this momment I have a oscillator to stable in a breadboard but in PCB is instable.. I think that is layout of my PCB is wrong in terms of GND, for example..
  18. Ron H
    Apr 14, 2005
    7,050
    657
    The circuit you posted won't work, partly because the op amp output is connected directly to one of the capacitors in the LC resonant circuit. My circuit works, at least in simulation.
  19. beirao
    Feb 22, 2012
    12
    Thanks for your attention. In this momment my circuit too works :) How I saida, the problem is in PCB and is problem os stability; but I will test your circuit too!
    Thanks!
