Colpitts generator Pspice
Discussion in 'Programmer's Corner' started by arek462, Jun 28, 2016.
  1. arek462
    Jun 28, 2016
    15
    Hello!
    I tried simulate Colpitts Generator from Horowitz's book:
    I use free pspice version, so there isn't crystal:
    Unfortunately it doesn't work like generator:
    If any expert could help me make it work right, i will be very grateful.
    Thank you!
  2. Bordodynov
    May 20, 2015
    669
    194
    See
    arek462 likes this.
  3. arek462
    Jun 28, 2016
    15
    Thanks for your help!
    Now i have problem with "floating node".
    How did you set ic=1mA because it may help?
    Also i have problem with "Undefined layout format....". It shows after i added my own transistor:
    Thank you!
  4. Bordodynov
    May 20, 2015
    669
    194
    floating node ==> comon node C1 and C7 add resistor 1Gig.
    IC = 1mA to speed up the calculation. It should .Tran 50m UIC. If you want to see the launch of the generator without these options, you must apply voltage leap. Note that I am one of the reduced capacities of up to 200 pF. There was no generation. Perhaps at a higher quality factor is generated. The lower quality factor, the faster the calculation.
    .model 2n5485 njf(is=.25p alpha=1e-4 vk=80 vto=-2.0 vtotc=-3m beta=3.5m lambda=10m betatce=-.5 rd=10 rs=10 cgs=4p cgd=4p kf=3e-17 )
    In your model, the transistor is too small capacity. See datasheet. Also, your transistor transconductance more than three times less. You may need to further reduce the capacity of the C3 (~100pF).
    arek462 likes this.
  5. arek462
    Jun 28, 2016
    15
    You mean add parallel resistor 1G?
    I've change C3 to 100p.
    How add .Tran 50m UIC?
  6. Bordodynov
    May 20, 2015
    669
    194
    The resistor is attached to the ground with one pin (you can parallel capacitor).
    Look in the job analysis. The option uic is valid for all Spice program (and for Pspice, ORCAD)
    I corrected my previous post!
  7. arek462
    Jun 28, 2016
    15
    Thank you.
    I added resistor and the floating node problem is gone. Howewer, circuit still doesn't work like i expected. Please help
  8. Bordodynov
    May 20, 2015
    669
    194
    You still get your hands on the option "uic".
    In another (initial voltage boost).
  9. arek462
    Jun 28, 2016
    15
    I really don't know how to make this tran 50m.
    Do you mean this?
    I should change only dc in source parameters??
  10. arek462
    Jun 28, 2016
    15
    I've change some simulation parameter and i got this:
    Is it correct?
    Thank you!
  11. Bordodynov
    May 20, 2015
    669
    194
    in Spice R3=1M=1m=0.001 !!! need 1Meg=1meg=1000000=1e6=1000k
  12. arek462
    Jun 28, 2016
    15
    Yea, you are right. My mistake.
    I change resistor's value to 1 Meg and now it looks this:
  13. Bordodynov
    May 20, 2015
    669
    194
    Just give me image of a circuit. Without waveforms. So that I can better see your circuit. Resistor correct. On waveform output power node. I want to be sure that in the zero voltage momet time zero and then changed to 24 volts.
    You may need to increase the accuracy of the calculation. Make reltol=10u. I did that when counting crystal oscillators. and I used Pspice4.
  14. arek462
    Jun 28, 2016
    15
    Now i know what you meant.
    So in the beginning voltage must be 0 and then after some short time 24V.
    Do you how to set it?
  15. Bordodynov
    May 20, 2015
    669
    194
    Yes, you understood me correctly. I usually use front enable 1 microsecond, but it is possible and faster. This gives the initial impetus fluctuations. And further. Do not use the default transistor. In the second scheme, I took the same model that you take.
    arek462 likes this.
  16. arek462
    Jun 28, 2016
    15
    So, what do you advice?
    Now i use this transistor .model 2n5485 njf(is=.25p alpha=1e-4 vk=80 vto=-2.0 vtotc=-3m beta=3.5m lambda=10m betatce=-.5 rd=10 rs=10 cgs=4p cgd=4p kf=3e-17 ).
    What should i do to get the same waveform like you in your first post?
    http://forum.allaboutcircuits.com/attachments/draft300_plot-png.108432/
  17. arek462
    Jun 28, 2016
    15
    Amplitude is to small. I don't understand it:
    I upload schematic.
  18. Bordodynov
    May 20, 2015
    669
    194
    You can simulate a text file. ORCAD allows you to do it.
    * D:\Program Files\LTC\LTspiceIV\Draft302.asc
    r1 g 0 1meg
    j1 out g 0 j2n5485
    r2 VCC out 4.7k
    c1 out n002 1000pf
    c2 out 0 1000pf
    c3 0 g 200pf
    l1 p001 g 0.159154943091895
    c4 p002 p001 1.59154943091895e-013
    r3 n002 p002 100
    c5 n002 g 2e-012
    v1 VCC 0 pwl(0 0 1us 24v)
    r4 n002 0 1g
    .model j2n5485 njf(beta=1.039m betatce=-500m rd=1 rs=1 lambda=4.25m vto=-2.5
    + vtotc=-2.5m is=33.57f isr=322.4f n=1 nr=2 xti=3 alpha=311.7 vk=243.6
    + cgd=1.6p m=362.2m pb=1 fc=500m cgs=2.414p kf=7.832e-003f af=1)
    .tran 0 50m 0 .1u
    .option reltol=1u
    .probe V(out) V(g) V(vcc)
    .end
    • gen.cir
      File size:
      581 bytes
  19. arek462
    Jun 28, 2016
    15
    I use pspice
  20. Bordodynov
    May 20, 2015
    669
    194
    This file is for Pspice. ORCAD Pspice uses. Before the calculation of the graphical design turns a text file. The text file and is used for the calculation. I used ORCAD9.1 and ORCAD9.2. They allow you to count text files, as well as other SPICE-program. I did it. Start my file!
