Yes you are correct.So if I calculate 8.5V with two 3.0V minimum forward voltage LEDs at 24mA current, I get 8.5 - 3 - 3 / .024 = 104 Ohm and round up to a 120 Ohm resistor I'll be getting 20.8mA at 3V fv or 14.1mA at 3.4V fv is my math right?
The first circuit shows the Japanese PNP transistors backwards.Or you could just try one of these....
I really like this schematic, but it's odd that it doesn't mention what voltage/current LEDs to use, so why even bother listing the amount of resistance on the resistors? If I dropped the LEDs I just bough in the blue line of that schematic, a 160 ohm resistor with a 12v source would burn them fast. Anyway, I think I could tweak it to my design. I'll go get to work on that.Or you could just try one of these....
http://makezineblog.files.wordpress.com/2010/10/ledcolororgan-schem_r2.gif
by Duane Benson
by Jake Hertz
by Duane Benson
