color correction
Discussion in 'General Electronics Chat' started by DexterMccoy, Mar 29, 2014.
Thread Status:
Not open for further replies.
  1. DexterMccoy
    Feb 19, 2014
    429
    How do you troubleshoot color correction boxes?
    You can't use a function generator , so what do you use to inject into the color inputs?
    NTSC, PAL, SECAM signals
    How do you Display the color waveforms on the o-scope?
    Because using a O-scope you can't view or display the color signal waveforms, why is that?
  2. ScottWang
    Aug 23, 2012
    4,933
    777
    google : color frequency.
  3. DexterMccoy
    Feb 19, 2014
    429
    what is the generator called that outputs color frequencies for NTSC, PAL, SECAM?
    Are they called color frequency generators or they use something else?
  4. DexterMccoy
    Feb 19, 2014
    429
  5. ScottWang
    Aug 23, 2012
    4,933
    777
    google:
    color signal generator.
    color bar signal generator.
    Color Tool.
  6. DexterMccoy
    Feb 19, 2014
    429
    But do you put the NTSC, PAL, SECAM signals into the O-scope external trigger , so you can view/display the Color frequency waveforms?
    NTSC, PAL, SECAM signals are a timing signal? or what kind of signals are they?
  7. ScottWang
    Aug 23, 2012
    4,933
    777
    google : "what are the NTSC, PAL, SECAM", "color bar signal generator".
  8. bertus
    Administrator
    Apr 5, 2008
    15,805
    2,389
Related Forum Posts:
  1. sby64
    1,409
Thread Status:
