The first answer isn't necessarily zero. Negative current times negative voltage yields positive power, after all.Oh. In that case, all the answers are zero.
My bad.
Yep. But that doesn't mean that no work was done on that resistor. Imagine an RC circuit in which the capacitor starts out with a certain charge on it. Then a voltage waveform is applied that puts some more charge on, takes all that and more off, and finally puts just enough back on to leave it at the same charge as before. How much charge was transferred off the cap? Zero. But non-zero energy was being dissipated in the resistor in each of those steps and that energy was supplied by the source that provided the voltage waveform.When a milliamp flows through a 5K resistor, and then you reverse the polarity and the current goes the other way for the same amount of time, no charge is transferred. Got it.
