College Assignment question need help!
unknown93
Joined Feb 13, 2013
The question is
An amplifier has an open-loop gain off 99db's, if 10% of the output signal is fed-back into the input in antiphase with input signal, determine:
(A) From the first principles the transfer function for the amplifier and
(B) hence determine the closed-loop gain of the amplifier
thanks :D
WBahn
Joined Mar 31, 2012
30,076
What efforts have you made to solve the problem (never forget, it is YOUR problem)?
Once you show your efforts, we will have something to hook into and help you make progress.
30,823
Geeze, you don't get it. There is no formula.
You have to work through the equations yourself.
We don't know. This is your problem. Show us what you think is the proper approach.
Start by drawing a diagram.
WBahn
Joined Mar 31, 2012
30,076
im not asking for the answer, i just don't have a clue how to answer it
so some sort of formulae would help
thanks
Can you draw a circuit diagram that matches the description given?
What is the relationship between the input voltages to the amplifier and the output voltage?
