Collector - Emitter Bias Calculation Help
Discussion in 'Homework Help' started by sparkey2000, Aug 5, 2008.
  1. sparkey2000
    Mar 9, 2008
    8
    Hi
    I have been trying to calculate this revision question. :confused:
    I have been able to calculate the base current however I need confirmation on how VCE is calculated.
    Many thanks
    Martin
  2. silvrstring
    Mar 27, 2008
    159
    Martin,
    Vce = Vcc - Vrc - Vre. Other than that, your work looks good.
    But when using (Beta+1)*Ib=Ie, there will be a greater difference in calculations between the real Ie and Ic as Beta gets lower. I asked my professor about the C-E setup, and he used Beta*Ib = Ic, and then Ic = Ie. Because of the previously mentioned problem, my advice is to use Beta*Ib=Ic when in a low Beta situation. I guess if you really wanted to be a perfectionist, you could do both.
    Take care
