cold cathode bottle lighting
Discussion in 'The Projects Forum' started by newfie, Nov 6, 2012.
  1. newfie
    Nov 6, 2012
    Hi everyone i have 6 dark blue loccaly made beer bottles. My idia is to make a compact frame to hang the bottles each with cold cathodes inside and a box to house a 4 channel splitter feeding 3 sound activated inverters to feed the 6 cathodes.Basically i am wondering if before i buy all the parts has anyone done this before or have any idia about sound holes or mounting and soo on.
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    What do you expect these "cold cathodes" to do when electrified? What type of voltage are they electrified with?
  3. Bernard
    Aug 7, 2008
    4,240
    414
    My sample cold K's operate at about 5kV from a 5V inverter. Bright white LEDs can be moduleted, or to flash like lightning.
  4. newfie
    Nov 6, 2012
    they come as kits i found out that they also sell wall adapters now sooo im not sure the exact specks i just know there real bright and provide a good light for the project
  5. newfie
    Nov 6, 2012
    the image you attached is similler but there will be a cold cathode and crushed glass inside instead of leds
  6. newfie
    Nov 6, 2012
    sorry i just realized i have not been exact all these parts i will be buying and they are normally used for p.c lighting inside the p.c case i plan on using them for something i dont thing anyone has done and soo more precicesly i am wondering A. if it can theasibly be done B. what sort of placement i need sound holes i.e do they need to be mounted externally or will holes in the frame work C.can this all be powered in the manner specified
    power adapter
    http://www.crazypc.com/products/pa-ad-ul-7422.html
    4 way inverter
    http://www.crazypc.com/products/4-way-inverter-823905.html
    sound module
    http://www.xoxide.com/cocasoackit.html
    cold kathodes
    http://www.xoxide.com/blue-cathode-6inch.html
    since ive never used these for this purpose i am not sure if im right in my assumptions also for the sound modules can the on off switched be removed.
