I am working on a project that involves accepting a coin and in turn open a gate. I only have basic knowledge of circuits and electronics. I looked for products that would fit my requirement, did not find any. Couple of products online might fit my purpose with some tweaking, but they are very expensive. So I decided to try on my own.
I purchased a Sintron CH-923 multi coin acceptor and tested it with a 12V battery for the coins I want to use, works perfectly well. I also purchased a cheap electric strike (Electric Strike Lock - Wood/Metal Door Fail Secure (NO)), it works fine when I apply power. Now I want to setup a circuit to trigger the strike when a coin is accepted. I tried using a Suzo Happ coin switch (used in laundry machines) to trigger the strike, without much success. The Coin Acceptor outputs pulse signals, I am now thinking of using that to trigger the strike. I need your help / guidance in setting up circuit for this.
Link for the manual for CH-923.
Thank you
Thank you
