Coil gun : capacitance Vs. Cost question
Status
Not open for further replies.
mahela007
Joined Jul 25, 2008
45
Hi.. I'm trying to design and build a coil gun. Basically, it's a device to accelerate a ferromagnetic projectile using a magnetic field. To produce the magnetic field, I've decided to use capacitors discharging through a solenoid.
I want to store as much energy as possible in these capacitors. Since large (i.e high capacitance) capacitors are expensive, I'm going with moderately sized capacitors at high voltage (400V).
This is where the question arises:
I could either use one large cap and charge it to 400V or I could use 2 or 3 smaller capacitors in parallel to provide the same capacitance. In terms of cost, it is much cheaper to buy several smaller capacitors (and wire them together in parallel) than to buy a larger capacitor of equivalent capacitance. However, I need to know if there will be any difference in performance between a single capacitor system and a multiple capacitor system..
(For clarification, the circuit just involves a solenoid connected in series with the capacitor(s) )
kubeek
Joined Sep 20, 2005
5,795
Actually, more smaller in parallel are better because it lowers ESR.
Just by the way, coilgun topics are restricted here.
SgtWookie
Joined Jul 17, 2007
22,230
Your topic is restricted under the Terms of Service, paragraph 6, which reads:
6. Restricted topics. The following topics are regularly raised however are considered "off-topic" at all times and will results in Your thread being closed without question:
  • Any kind of over-unity devices and systems
  • Automotive modifications
  • Devices designed to electrocute or shock another person
  • LEDs to mains
  • Phone jammers
  • Rail guns and high-energy projectile devices
  • Transformer-less power supplies
In the future, please refrain from originating topics that are on the Restricted list, or other topics that can be hazardous to people or property.
The Terms of Service can be viewed by clicking on this link:
http://www.allaboutcircuits.com/l_tos.html
Status
