Code to inverse a matrix
Discussion in 'Programmer's Corner' started by blindoffaith, Aug 22, 2005.
  1. blindoffaith
    Aug 22, 2005
    Hi
    This is my first post here so enjoy ;)
    I'm looking for a code that obtains the inverted matrix of a given matrix
    using the Gaussian elimination method ( http://en.wikipedia.org/wiki/Gaussian_elimination)
    the code is found on the bottom of the page linked above :
    i=1
    j=1
    while (i ≤ m and j ≤ n) do
    # Find pivot in column j, starting in row i:
    max_val = A[i,j]
    max_ind = i
    for k=i+1 to m do
    val = A[k,j]
    if abs(val) > abs(max_val) then
    max_val = val
    max_ind = k
    end_if
    end_for
    if max_val ≠ 0 then
    switch rows i and max_ind
    divide row i by max_val
    for u = 1 to m do
    if u ≠ i then
    add - A[u,j] * row i to row u
    end_if
    end_for
    i = i + 1
    end_if
    j = j + 1
    end_while
    this code seems to work but not quite well or i have trouble doing it right .
    also i'm interested in other source codes for matrix inverting .
    i tried to work with this one because it's probably the fastest.
    PLEASE HELP ME I"M DESPARATE
  2. aibelectronics
    Member
    Aug 26, 2005
    24
    Where does the code not work well? I think if you told us where it starts behaving erratically we'll find it easier debugging it.
    would the language we use for the source code matter? personally i use c & fortran I don't know if you'll have problems with them?
  3. blindoffaith
    Aug 22, 2005
    thanks for the help but i've figured it out by now . ..
    i mean it really works.
