code problem - using 8051 microcontroller (AT89S52)
Discussion in 'Programmer's Corner' started by Muhamad, Mar 31, 2015.
Thread Status:
Not open for further replies.
  1. Muhamad
    Mar 31, 2015
    14
    I have problem when compiler this code, can anyone help me?
    I use keil software.. This is the problem that i got
    Build target 'Target 1'
    compiling My.c...
    My.c(2): warning C318: can't open file 'lcddisplay.h'
    My.c(16): warning C206: 'lcd_init': missing function-prototype
    My.c(17): warning C206: 'lcdcmd': missing function-prototype
    My.c(17): error C267: 'lcdcmd': requires ANSI-style prototype
    Target not created.
    This is my code..
    #include<reg51.h>
    #include"lcddisplay.h"
    #include<intrins.h>
    sbit rd = P2^0;
    sbit wr = P2^1;
    sbit intr = P2^2;
    sbit finger = P2^5;
    sbit buz = P2^3;
    #define adcdata P3
    void convert(unsigned char );
    unsigned char a,pp=0,count=0,i;
    void main()
    buz=0;
    finger=1;
    lcd_init();
    lcdcmd(0x85);
    msgdisplay("WELCOME");
    lcdcmd(0x01);
    msgdisplay("temp hbeat");
    rd=1;
    intr=1;
    adcdata=0xff;
    while(1)
    lcdcmd(0xc2);
    //delay(500);
    wr=0;
    _nop_();
    _nop_();
    _nop_();
    _nop_();
    wr=1;
    delay(50);
    rd=0;
    delay(10);
    a=adcdata;
    convert(a);
    delay(500);
    for(i=0;i<100;i++)
    count+=1;
    if(finger==0)
    delay(1000);
    if(!finger)
    buz=1;
    delay(500);
    pp=1;
    buz=0;
    break;
    else
    pp=0;
    delay(500);
    lcdcmd(0xca);
    if(pp)
    convert(count);
    else
    convert(0);
    pp=0;
    void convert(unsigned char temp_value)
    unsigned char value,d1,d2,d3;
    temp_value = temp_value;
    value=temp_value/10;
    d3=temp_value%10;
    d1=value/10;
    d2=value%10;
    d1=d1+0x30;
    lcddata(d1);
    delay(10);
    d2=d2+0x30;
    lcddata(d2);
    delay(4);
    // msgdisplay(".");
    d3=d3+0x30;
    lcddata(d3);
    delay(10);
    Can anyone help me to fix the code?
  2. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    The compiler can't find the include file. The other errors are a result of this.
    Putting the file name in quotes implies that the file is in the same source location as the .c file. Putting it in brackets i.e. #include <file.h> will tell the compiler to look in standard places (a directory called INC maybe. You can also specify the search paths for includes (and other files) in the project configuration.
    " " and <> searching can vary with the compiler implementation. Check the manual for your compiler.
    Good luck.
  3. MrChips
    Oct 2, 2009
    12,635
    3,453
    Search your computer disk to locate lcddisplay.h
  4. Muhamad
    Mar 31, 2015
    14
    When i use " " or < > still have a error
  5. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    As Mr. Chips says, be sure the file actually exists - and that the LCD library it describes likewise exists.
    When you find both, add the path to the files to the project configuration so that the compiler can find the .h file and so the linker can find the library.
  6. Muhamad
    Mar 31, 2015
    14
    i cannot find it in my computer, what should i do?
  7. Muhamad
    Mar 31, 2015
    14
    if the file no exist, what should i do?
  8. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    You are trying to use code that requires LCD support routines that are in a separate library. You have a couple of options 1) go back to where you got the code and see if you can get the library it needs to compile 2)write your own LCD routines 3)see if the Kiel compiler has any libraries that don't get installed by default and install them. If the code was originally written for another compiler - especially MikroC - the libraries were probably installed as part of the development package. Now they are missing. You could search for *.h (all header files) and see if there is something that looks like it - maybe its misspelled or there's a different version.
    As it stands, the code won't compile/link because it is incomplete.
    If you want to code your own LCD routines there are many, many threads here on AAC that discuss that topic in great detail. Search away!
    Good luck
  9. Muhamad
    Mar 31, 2015
    14
    Can you teach me how to add the .h header? I still new with the software that i use.
  10. JohnInTX
    Jun 26, 2012
    2,394
    1,051
    Not really, because there is nothing to teach. You don't have the file(s) you need to complete the code so you are left with the options I noted.
    Its like you were cooking a recipe which described how to prepare and cook the meat but referred you to another cookbook for the sauce. You go to the shelf and that cookbook is missing - no sauce - no dinner. Whoever wrote the original code used parts from another 'cookbook' i.e. the LCD library. Without that, you are on your own to find the library, with its .h file that is like a description of what functions is has in it, and put the files where the compiler can find them. Once you have the files, look in Keil's help under Libraries and it will tell you what it wants.
    But you gotta have the files - the .h AND the library that goes with it - or write your own. Sorry, that's about all there is to it.
  11. ScottWang
    Aug 23, 2012
    4,930
    777
Thread Status:
