code help for microcontroller
Discussion in 'Embedded Systems and Microcontrollers' started by KAGAN09, Apr 27, 2011.
  1. KAGAN09
    Mar 12, 2011
    7
    i need a code for the following
    XXXXXXXX
    XXXXXXXO
    XXXXXXOX
    XXXXXOXX
    XXXXOXXX
    XXXOXXXX
    XXOXXXXX
    XOXXXXXX
    OXXXXXXX
    X is void
    O is water drop
    im a newbie. i need this fast. ill appriciate all help. Thanks
  2. nerdegutta
    Dec 15, 2009
    2,565
    806
    I might be totally ignorant but I don't get this...
    What is this?
    What are you trying to accomplish?
    Schematic?
    I don't get it.
  3. KAGAN09
    Mar 12, 2011
    7
    ohhh sorry, im trying to write a microcontroller code to do that thing i wrote above. Anything that does that function would do.
  4. nerdegutta
    Dec 15, 2009
    2,565
    806
    Still not getting it...
    Maybe you should make a drawing of what you are trying to do, and a schematic...
    Program what MCU?
    In what programming language? C, assembler or ...
  5. t06afre
    May 11, 2009
    5,939
    1,222
    Can you elaborate we are still puzzled here.
  6. KAGAN09
    Mar 12, 2011
    7
    okai. now im doing a waterfall display printer. its got im going to control fast solenoid valves. hmmm pin numbers can be made up ill change them. im gonna use a z8 microcontroller. or assembler code it doesnt matter.
  7. KAGAN09
    Mar 12, 2011
    7
    more detailed ive got a picture i change it to binary picture (black and white) these values turn valves on/off. i haven't decided on the valves im testing a few so i don't have a schematic. for now im just putting in constant values to see if the valves can open close fast enough. im going to use a already built calculator microcontroller z8 board.
  8. John P
    Oct 14, 2008
    1,638
    225
    Is this by any chance a school project where you've done nothing and now have a deadline looming? I'm afraid the way you've described this projet makes it seem as though you have very little knowledge of what's needed.
    When you get a controller running, you'll need precise control of timing, you'll need an interface circuit to get from the processor's voltage to the valves' voltage, and you'll obviously need the valves themselves, and they need to be fast enough to produce precise droplets. If you have some valves to test, you could do that without a processor, with a 555 timer for instance.
