code function 6 Response Modbus
Discussion in 'General Electronics Chat' started by btb4198, Jul 15, 2013.
  1. btb4198
    Jul 8, 2013
    6
    ok so I have Experion server that is sending my c# program a code function 6.
    which is what it should be doing because I want experion to change a value in my C# program. that value is the OP...
    ok I can see that experion is sending the value. however, the program most not be sending the right Response because after a few seconds Experion fails out.
    I read some where online that if you get a code function 6 from a master your response should be the same thing the master send you...
    so that is what I am trying and it is not working...
    this is what I am getting from experion
    6
    78
    39
    45
    238
    244
    and I change my OP to 45 or 0 + 45 = 45
    so what should the response be?
  2. btb4198
    Jul 8, 2013
    6
    Never mind ... I got it to work
    Thanks anyway
