Code for OLED display
Discussion in 'Programmer's Corner' started by tarts, Oct 23, 2010.
  1. tarts
    May 27, 2009
    9
  2. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    You have bought a pig in a poke. I can find some data sheets to the display, but they are stamped "CONFIDENTIAL", leading me to believe they are not intended to be in the public view. I am not going to post the links.
    You will need some sort of data sheet to describe the operation of the display, however. Without that, no amount of programming can do much good (unless there is some standard for such displays, so the I/F is well understood).
  3. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    How can something be an OLED, LCD & LED display?
  4. tarts
    May 27, 2009
    9
    There is a link in ebay advertisement for UG-2864AMBAG01 manual. There is not much information regarding chip operation. However it says: For Commands Refer to the Technical Manual for the SH1101A. So this is the actual chip then!
    http://www.crystalfontz.com/controllers/SH1101A.pdf
    So is It possible to make it work based on this datasheet?
  5. tarts
    May 27, 2009
    9
    Haha, its a typical trick to cach customers in ebay :)
