Coaxial video to Composite Output
Discussion in 'The Projects Forum' started by Dalaran, Jan 12, 2010.
  1. Dalaran
    Thread Starter Active Member
    Dec 3, 2009
    168
    Do you know of a good/relatively cheap ic that can covert normal analogue video from my coaxial cable into composite video and audio?
    Appreciate all hep.
  2. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    What;s the video source? Antenna? Cable TV?
  3. Dalaran
    Dec 3, 2009
    168
    Right, as much info as possible.
    The application is to aid my brother in his living room setup (TV/receiver/speakers). He wishes to use a receiver to control sound in the room, however the receiver does not have a coaxial input for normal cableTV. His current solution is to go into the TV with the coaxial cable and then use the audio out to receiver. However it seems that the audio output is controlled by the volume control of the TV (even mute). He then needs the speakers on the TV on if we wants to run his towers, etc through the receiver.
    I'd like to make a circuit to take this coaxial cableTV and get composite (component if possible?) plus stereo out.
    Is this possible? Is there a common IC out there that can accomplish this?
    Thanks.
  4. retched
    Dec 5, 2009
    5,201
    313
    you can get a $5 converter/adapter and coax-y. And just use the audio outs.
    ie:
    A coax -y-splitter..
    1 end to the tv
    1 end to the adapter
    audio Left and Right from the adapter to the amplifier/reciever
  5. Dalaran
    Dec 3, 2009
    168
    Yup good call... so I guess its probably going to cost me more to make it eh?
    Appreciate the help.
