Coaxial cable vs. antenna
Discussion in 'Wireless & RF Design' started by kubeek, Mar 25, 2009.
  1. kubeek
    Thread Starter AAC Fanatic!
    Sep 20, 2005
    4,689
    806
    I just had a thought ;)
    If I take a (maube λ/4 long?) pice of coaxial, and connect ground to the central wire and signal to the outher shilelding, will it work like an antenna or not? Or just a little?
  2. Wendy
    Mar 24, 2008
    20,772
    2,540
    It will resonate, it can act as a very narrow bandpass or notch.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    It's a bit more successful if you can strip the insulation at the 1/4 wave length measurement. Remove the insulation of the 1/4 wave section, and work the exposed braid down over the insulation to leave the center conductor as the receive/transmit element.
  4. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
    Another option (like beenthere) make a little hole in the braid pull the centercore through
    and stretch the braid in opposite direction of the core.
    You will end up with an open dipole.
    Greetings,
    Bertus
