CMOS SPDT IC Operation
Discussion in 'Electronics Resources' started by daneloctober, Jan 20, 2013.
  1. daneloctober
    Mar 22, 2012
    7
    Hello guys! I'm not sure if this is the right forum category to put this in, but anyway, here's my concern:
    I'm planning to use a CMOS SPDT IC and I was just wondering if it really, truly acts as a relay? I mean, for example, based on the functional diagram below:
    If I put 4 volts in S2 with input at logic zero, then is the 4 volts I will get from D actually physically connected to the 4 volt supply in S2? I mean, will the current flowing out from D be actually sourced from the S2 supply?... I'm sorry if this is a dumb question, I'm such a newbie...
    Anyway, thank you very much for any help you can give! =)
  2. thatoneguy
    Feb 19, 2009
    6,357
    718
    From the Datasheet, the IC is designed to switch analog signals, so the terminals are connected, with the limitations shown in that link.
    daneloctober likes this.
