CMOS sensor size
Por Qué
Joined Mar 31, 2013
24
Hi all,
I try to design a CMOS sensor (without lense ) to capture an object of size 2 cm² and I didn't find the necessary equation to calculate the size of this sensor. In this case, is the sensor has the same size as the object?
Thank's
30,823
You really need to give us the part number of the sensor and possibly a link to documentation and datasheet.
I would think that you need a lens.
kubeek
Joined Sep 20, 2005
5,795
Oh not again.. Do you understand that without a lense the cmos sensor will only see a big blur of light? You can use a single photodiode and get the same result.
Get a piece of tracing paper and put it in front of that object you want to detect. Do you see anything apart from a shadow? Now put a lense somewhere in between, you will see a nice sharp image.
Por Qué
Joined Mar 31, 2013
24
the role of the lens is just to focus the rays of light, so place the image of the object on a small area of the sensor, so if we just design this small area is the lens is still necessary? If it has another role tell me.
thank's
