CMOS sensor size
Discussion in 'The Projects Forum' started by Por Qué, Apr 2, 2013.
  1. Por Qué
    Mar 31, 2013
    24
    Hi all,
    As part of the design of CMOS sensor I want to calculate its size and I found the following equation :
    A=(Y*N)/T with:
    A: Sensor size (in pixels)
    Y: field of view
    N: number of pixels assigned to the Body to be filmed
    T: size of the smallest detectable body
    my question is this the correct formula to calculate the size ?
  2. Por Qué
    Mar 31, 2013
    24
    please help :confused:
  3. kubeek
    Sep 20, 2005
    4,691
    806
    Doesn´t look correct to me, or actually, what is the unit of filed of view?
  4. Por Qué
    Mar 31, 2013
    24
    its Degree isn't it ?
  5. Markd77
    Sep 7, 2009
    2,803
    594
    What are the units of all of them?
    A = width / height / total number of pixels?
    etc
    What bodies are you talking about?
  6. Por Qué
    Mar 31, 2013
    24
    the body is the retina and its unit is mm
    the smallest part detectable in the retina its unit is µm
    the number of pixels not yet determined
  7. kubeek
    Sep 20, 2005
    4,691
    806
    A simple unit check will show that this cannot be correct:
    number of pixels = number of pixels * degrees / meters
    Field of view would have to be in meters for this to be of any sense.
