CMOS operational amplifier design
Discussion in 'Homework Help' started by Mohamad, May 25, 2010.
  1. Mohamad
    Jun 16, 2007
    Hello Friends,
    I'm taking an electronics course this semester and i got to do a small homework project like for this course..
    the amplifier is a differential input single ended cmos op amp
    it has to meet the following specs as in the figure
    I should use a positive +VDD/2 supply and a negative –VDD/2 supply only.
    The requirement to have VOS = 0 V means that there should be no differential mode offset; for a 0 V differential input and a common-mode input at the midpoint of the common-mode input range, the output should be 0 V under nominal supply conditions.
    I am free to choose the midpoint of the common mode input range.
    The available components are: NMOS transistors, PMOS transistors and resistors. Ideal sources can only be used to generate the supply voltages, not to generate bias currents.
    Device Models
    The device models are encapsulated in a sub-circuit; use:
    x1 d g s b nmos w=10u l=0.13u
    x2 d g s b pmos w=10u l=0.13u
    The sub-circuit definitions are as follows:
    .subckt nmos d g s b params: w=10u l=0.13u
    m0 d g s b nmos_internal w={w} l={l}
    .model nmos_internal
    + nmos level=1 kp=500u vto=0.3 gamma=0.2 phi=0.6
    + ld=0.025u
    + lambda={0.2*exp(0.13u/{l})/exp(1)}
    .ends
    .subckt pmos d g s b params: w=10u l=0.13u
    m0 d g s b pmos_internal w={w} l={l}
    .model pmos_internal
    + pmos level=1 kp=120u vto=-0.3 gamma=0.2 phi=0.6
    + ld=0.025u
    + lambda={0.15*exp(0.13u/{l})/exp(1)}
    .ends
    i'm finding this very difficult to achieve
    i tried something on a draft and is as follows:
    am i close to something ??? any suggestions ?? how to assign a value for every transistor ?
    how to complete the schematic ?? and examples close to what i'm going to do
    thank you in advance
  2. aimiazri
    Jan 7, 2010
    6
    i dont really know act.. but, i have read it.. try to get reference from book CMOS Analog Circuit Design. Philip E. Allen & Douglas R Holberg..
