CMOS is faster than TTL?
Discussion in 'General Electronics Chat' started by watsongrey, Nov 3, 2014.
  1. watsongrey
    Oct 31, 2014
    94
    Is CMOS Logic faster , faster switching than TTL logic?
    CMOS switching time is faster and less propagation delay time?
    Why did designers switch from TTL to CMOS?
  2. Papabravo
    Feb 24, 2006
    10,340
    1,850
    Yes, but you have a troll-like name and you're asking very troll like questions.
    Got any autopilot schematics?
    jpanhalt, shortbus and tshuck like this.
  3. watsongrey
    Oct 31, 2014
    94
    Any reason why CMOS is faster than TTL?
  4. crutschow
    Mar 14, 2008
    13,482
    3,370
    Some varieties of CMOS are faster than some varieties of TTL and vice versa.
    The reason for changing from TTL to CMOS is that CMOS uses less power.
  5. watsongrey
    Oct 31, 2014
    94
    how about propagation delay times , is it true that CMOS has less propagation delay time compared to TTL propagation delay time?
  6. watsongrey
    Oct 31, 2014
    94
    Any reason why a CMOS take less power or current draw compared to a TTL Ic chips?
    What makes a CMOS IC chip takes less power and current draw
  7. joeyd999
    Jun 6, 2011
    2,756
    2,923
    Have you considered Wikipedia?
    ErnieM likes this.
  8. ScottWang
    Aug 23, 2012
    4,925
    777
    The fets were inside of the CMOS IC and they work by voltage, the bjts were inside of the TTL and they work by current, so the COMS IC just need less power, but the TTL need more current and power.
    You can see the R values of TTL circuit are more less then the CMOS circuit, and the CMOS circuit can using a resistor with higher value as 1M or some more.
  9. watsongrey
    Oct 31, 2014
    94
    ok i get it thanks scott wang
  10. ScottWang
    Aug 23, 2012
    4,925
    777
    BCD counter:
    CD4518 - CMOS
    5V - Fmin = 1.1Mhz
    10V - Fmin = 3Mhz
    15V - Fmin = 4Mhz
    http://pdf.datasheetcatalog.com/datasheets/120/109587_DS.pdf
    74HC4518 - CMOS
    5V - Fmax = 61Mhz
    http://pdf.datasheetcatalog.com/datasheet/philips/74HCT4518.pdf
    74HC390 - CMOS
    Fmax = 66Mhz
    http://pdf.datasheetcatalog.com/datasheet/philips/74HC_HCT390_CNV_2.pdf
    74AC390 - CMOS
    Fmax = 160Mhz
    http://pdf.datasheetcatalog.com/datasheet/toshiba/4247.pdf
    74LS90 - TTL,5V
    cp0 : Fmin = 32Mhz
    cp1 : Fmin = 16Mhz
    http://pdf.datasheetcatalog.com/datasheet/motorola/SN54LS92J.pdf
  11. MrChips
    Oct 2, 2009
    12,624
    3,451
    74F160 -TTL 5V 120MHz
    ScottWang likes this.
  12. ScottWang
    Aug 23, 2012
    4,925
    777
    The ECL Translator Guide
    PECL • LVPECL • NECL • TTL •
    LVTTL/LVCMOS • CMOS
    Prepared by: Paul Shockman
    ON Semiconductor
    Objective
    This application note is intended to provide the basic
    device selection and connection information to enable signal
    translation interface between ON Semiconductor’s ECL
    logic operating in various supply modes This document also
    provides information regarding translation between our
    ECL devices and TTL (5 V), CMOS (5 V), or
    LVTTL/LVCMOS (3.3 V) devices. For translation interface
    with LVDS, see AN1568.
    The ECL Translator Guide APPLICATION NOTE.
  13. alfacliff
    Dec 13, 2013
    2,449
    428
    and high current counters like ecl with only a half volt from 1 to 0 count to over 1000 mhz, but at the expense of high current. different families of logic have different reasons, some are fast, some use very low power, and some mimic other families like the FC series uses cmos to mimic ttl, but with cmos power levels.
  14. watsongrey
    Oct 31, 2014
    94
    But is CMOS faster at switching from input to output compared to TTL logic chips, and CMOS has less Rise time and fall time, less delay from input and ouput?
  15. alfacliff
    Dec 13, 2013
    2,449
    428
    cmos has oless current drive capability. so arise time and fall time is slower.cmos, being voltage driven, and cmos transistors having more capacitance on gate to source, have slower times. cmos can be made to be similar to ttl, but still, the main advantage for cmos is power disapation.
  16. BobTPH
    Jun 5, 2013
    806
    121
    The TTL and CMOS logic chips that you see still being used today are decades old. Intel's version of CMOS, used in its microprocessors, is orders of magnitude faster any TTL or CMOS logic chips, running as high as 4GHz clock speeds. The propagation delays are in the picosecond range.
    Bob
  17. watsongrey
    Oct 31, 2014
    94
    So a FET switching time , rise time and fall time is "slower at switching" compared to a Transistor switching time? so a transistor switches faster then a FET? a transistor has less rise time then a FET?
  18. BobTPH
    Jun 5, 2013
    806
    121
    No. There are extremely wide overlapping ranges of switching time of different kinds of transistors.
    In practical use, most high speed logic is now CMOS because bipolar logic of any kind uses too much power. Bipolar transistors are probably still used in some specialty hardware for speed where power is not a problem.
    Bob
  19. MrChips
    Oct 2, 2009
    12,624
    3,451
    The increase in speed is primarily a result of lower operating voltage and smaller feature sizes: less charge to move around.
  20. BobTPH
    Jun 5, 2013
    806
    121
    Yep.
    One difference between CMOS and any bipolar logic is that in CMOS there is not current flowing in the steady state, since you have two complementary transistors with one on and the other off going from Vdd to Vss. (okay, there is leakage current, but this is small) So, current flows only when they switch. With bipolar transistors you have to have current flowing all the time to make the speed of switching reasonable.
    Bob
