CMOS AND gate
Discussion in 'General Electronics Chat' started by tejasdj12, Oct 25, 2012.
  1. tejasdj12
    Jul 11, 2010
    20
    Hello Guys,
    This should be my first thread. I'm a Electronics and Telecom student. Electronics is my current hobby. I'm quite new to some circuit concepts.
    Today, I was playing with MOSFETs and designed an AND gate with it (Circuit I). After that, I googled and found another circuit (Circuit II). Is it fine that I don't add another pair of MOSFETs (MOSFETs 5 and 6 in Circuit II)? Or are there any sourcing or sinking problems with Circuit I?
  2. Ron H
    Apr 14, 2005
    7,050
    657
    In circuit 1, your output is connected to the power supply. How is the output going to change?
    Circuit 2 is a NAND gate. You have to add an inverter (NOT gate) to the output to make it an AND gate.
  3. JMac3108
    Aug 16, 2010
    349
    66
    You have your MOSFET symbols reversed. The IRF530 is an N-chan, but you show it as a P. The IRF9530 is a P-chan, but you show it as an N. You should probably redraw the circuit correctly so its better understood so people can comment on it.
  4. tejasdj12
    Jul 11, 2010
    20
    Even if one of the input goes LOW, at least one MOSFET will start conducting. It will be a least resistive path (I think). So current should flow through either of the MOSFETs when input is LOW
  5. tshuck
    Oct 18, 2012
    3,531
    675
    Circuit1 is not CMOS. CMOS stands for complementary metal oxide semiconductor, what you have isn't complementary, add you have only one type MOSFET.
    Also, circuit two is an AND gate, but the PMOS and NMOS positions are flipped from their usual locations, NMOS on bottom when drawn....
  6. takao21203
    Distinguished Member
    Apr 28, 2012
    3,578
    463
    You'd get such problems if you build larger circuits, and use higher frequencies. Of course the circuits do not work if they are directly built as shown. Maybe OP is aware of this.
  7. tejasdj12
    Jul 11, 2010
    20
    Sorry, the editor I used was messed up I think. Here's the new circuit diagram:
    And I was asking why Circuit I would fail? When both inputs for Circuit I are HIGH, both Q5 and Q6 will act as open and Y will be HIGH. In case any of the inputs are LOW, current would directly sink through one of the MOSFETs. So Y will be LOW. Then is there any need to add the additional two n-MOSFETs in Circuit II?
    @takao21203 Which problems? Can you elaborate a bit
  8. takao21203
    Apr 28, 2012
    3,578
    463
    tejasdj12 likes this.
  9. JMac3108
    Aug 16, 2010
    349
    66
    In circuit I you need to flip your MOSFETS over so that the source is connected to VDD. Then, a low at the input turns on the FET,a high keeps it off.
    BUT, the circuit won't work anyway. When you turn on Q5 or Q6 you short VDD directly to ground. Bad idea :rolleyes:. You need to limit the current, maybe add a pull-up resistor in series with VDD?
  10. tejasdj12
    Jul 11, 2010
    20
    Yeah, this was just an example. Anyways, thanks a lot for your help!!
  11. Ron H
    Apr 14, 2005
    7,050
    657
    In either case, you can't get the output to change when it is tied to a supply rail, either VDD or GND.
  12. takao21203
    Apr 28, 2012
    3,578
    463
    Such an AND gate would rather be an emulation of a TTL circuit (i.e. using a resistor to get the voltage drop). CMOS OR is based on a CMOS NOR, and a CMOS inverter.
    There are some good websites, but you have to dig 50 or 100 links, skipping the tuna encyclopedia websites (means spawned from Wikipedia, which isn't totally wrong as a starting point, or containing more adverts than information, if any).
    CMOS is the main search word, you need to add some additional terms, like gate, logic, mosfet, digital, simulation, etc.
